Bolt on spacers
You don't need 15x10's on that size tire. My opinion is get 8" wide rims.
Street legal beadlocks are expensive! A lot of the cheaper beadlocks are not DOT approved if that matters to you.
I don't think you'll need beadlocks tho. If I was you I'd run a 15x8 with a good backspacing. I've never been a fan of 10" wide rims unless you have 14" wide tires.
Well I got down to business today, and I have much more serious issues than just wheels.
Turns out that I have two warped rear drums, which would be why I have MORE vibration under braking... And I also have a bent rear passenger side axle shaft. Without a dial indicator, but a mechanical run out gauge it is definitely not even close to true.
Issue solved on the wheels. Instead of wheels, i'll be looking to buy chromoly axles and new drums.
Yay!!! Empty my bank account!
i had the same problem. decided to try the e brake while driving and could feel the shake get worse. new drums and im good to go. at $40 a side it wasnt a bad problem either.
