blown gasket
kibgreene
can anyone help me determine weather i have a blown head gasket or and/ or a intake manifold gasket, ive got the intake off right now.
2.9s don't blow head gaskets, they crack heads. what are the symptoms that you are having?
I put UV dye in my antifreeze which I purchased from Autozone (5.99) and ran it a bit. Used my UV LED flashlight and saw dye around the rear plug on the right side head.
Going to replace both heads/push rods/lifters/timing chain etc. Engine has 141K but uses no oil.
It would be much easier to check with the engine running
It's much much MUCH easier to do this with the engine assembled.
If you can SEE a crack -- the common places are at #1 and #6, and it is very often visible on top for 2.9Ls -- you know you have a cracked head.
But you haven't established (at least to us) that the engine is leaking coolant internally, or even at all. Mysteriously disappearing coolant is sometimes explained by a failing water pump, much more often than one might expect. Are you chasing coolant in the crankcase?
