BL, 33's, wheels, installed (pics)
dbp
PA
Front:
Rear:
Side: (looks kinda bad because the rear bumper was not put back on when I took the pic).
All in all, took about 8 hours to do...By no means would I consider that an easy job...and the pictures in the PA instructions are pretty bad.
I had to get 4 bolts, 8 washers, and 4 nuts because I couldn't find any in the kit to put the rear bumper back into place...but the brackets that the kit came with relocated everything nicely.
Oh yeah...any tips on the manual tranny shift lever...when the console is installed and the boot is put in place, it hits the console trying to get into 2nd...so I just have the boot sitting on top of the rear part of the console.
Only thing I can think of is notching it out or something right where 2nd is. Not that you can tell how I have it...looks like it's in place.
Yeah I used the correct extension. Put it like this...if the boot was removed, and you watched the shifter lever, it would come probably 1/8" close to the console. With the boot in, it hits. It will still go into second, but I could see myself cruising along, lazily shifting into 2 and grinding my gears. I think I'm just going to either leave it or notch that plastic console part right there out just a little.
