Biggest Ranger In Jersey???
Love it, she's come a long, long way.
have you thought about the exhaust set-up?
I'm thinking sleaper may have been bypassed 6ft ago.
Frank
exhaust is coming out the fenders around the blinkers somewhere through stainless through the body flanges. twin turbos thats why I went with this motor they make tons of power when not natural aspirated
Does anybody know where to find a tcase from an all terrain forklift Ive been searching but no luck
Thanks for proving guys with little trucks, can be insecure too. W/E, if you don't like the truck don't post on the thread.
All terrain fork truck? can you elaborate? I honestly think I know where one of exactly what you are after is at (behind my buddies diesel shop) the mines used it to move bigash crates, and scafoldings. If you can kinda tell me about it, I can get you his number, then maybe he can get you a number to the guy you'd be after.... But this is all the way in KY and you'd have to have a string of bad luck not finding one up north to consider it.
Frank
ill ask my local yard if theres any laying around. im even surprised about what they have lying around sometimes
lull 644E-42 is a good example there are alot of other brands Gradall bobcat sky trak they all utilize the same type of case and normally have 1to1, 3to1, 6to1. ratios but im not picky if it only has hi and low thats fine
I searched photos, that looks exactly like it but different color, and older style.
I'll call Luke, and have him get me a model number. Then I can check what transfers they came in.
Frank
Looking good man, how much metal are the braces going to be?
2x2 1/8th wall and where the tube ties into the frame Ill put 1/4 steel inbetween the frame and tube to reduce shearing. At each point where the tube hits the frame Ill box the frame about a foot with 1/4 steel plate, ive seen too many fully boxed frames crack there meant to have some flex.
getting the fuel system started
Installed the new distributor and powder coated water pump housing with electric pump and the aeromotive fuel pressure regulator
also had to support the front of the truck and remove the link bars to get the right hand thread heim joints out the ball on each joint has started to rust which will destoy the joint in a few hours of use. Qa1 is taking them back but the truck is stuck up on blocks again untill the new ones arrive
Upcoming TRS Events
Featured Ranger Based Vehicle
