dusten
Big brake kits for gen 1 lightning.I have come to the conclusion that nobody in the history of hotrodding and extreme off roading have every built a late 80s/early 90s F150.... I come to this conclusion because there is absolute ZERO aftermarket support for brakes for an F150....
Seriously, how fracking hard should it be to find multi-piston calipers?
Just spit balling here but would it be possible to lengthen D50 TTB beams to fit where a 5 lug D44 beam goes? I don't care about converting to 8 lug.... I just want long travel TTB with enough stopping power to clamp down on the 315/75/16 load E Mickey Thompson Baja Claws I am going to buy. Even with hydro boost on the stock or even the laughable "high" performance single piston calipers and rear disc conversion is not going to be enough to stop quickly at hwy speeds......
Any suggestions or links?
Use those calipers, fan your own brackets
http://www.tceperformanceproducts.com/lightning-and-harley-f150/kits-18/
