- Mar 17, 2013
- Age
- 32
- Gresham, Or
Think you could be persuaded to make one for a m50d-r2
How did you mount the engine to clear the oil pan against the crossmember. And what did you do exactly with the rad?
All the engine management wiring can go short of the temp,oil,tac and a key on 12v. If you have a tac, then you can get it to work using an ABS sensor on the ballancer w/3 notches (if your motor was a v-6). One wire to 12v and the other to the signal terminal on the tac, thats what I did and it works prefect.
If there was enough interest in the adapter like i made i could tear apart and measure it up and make few but id have to have a few people to make it worth my while that are willing to pay for for it more i get cheaper i can make them
OM617 to Small Block Ford bellhousings with 164Tooth flywheels or flexplates transmission Adapter Kit. The Small Block Ford pattern was used in many Inline 6 cylinder engines and V8 engines. This kit will NOT fit V6 or Big Block Ford engines.
Here are several known manual transmissions that will work:
T18 - 4 speed, T19 - 4 speed, T5 - 5 speed, NP435 - 4 speed, M50D-R2 - 5 speed.
Price: $455.00
If I'm not mistaken the bolt pattern to the bell housing on the fm145 is the same as that on the t 5 transmission and Id like to know if this is true cuz if it is there are more kits available to adjust the gearing in the transmissions if you wanna go that far. My bell is also designed so you can use the factory Mercedes flywheel and clutch but uses the friction plate from the clutch system on fm145 to match the spline.
