Bedliner in a can, which one?
Sprayed on the paint, rolled on the herculiner. I used Krylon ultra flat camo green. Painted it on after about 4 hrs, while the herculiner was still tacky. Turned out really well, matches the rest of the truck. You can see a texture difference but thats expected.
well i went with the rustoleum, and for 16.95 a qrt at lowes wasnt bad, also got the duplicolor roller kit...turned out nice
Looks good. Seems like the Rustoleum is a lot smoother texture than the Herculiner.
Spray on is the ONLY way to go. That roll on crap flakes off in as little as a few weeks or a couple years.
sucks to be you. quality comes at a cost. rhino or linex is the only way to go. been there, learned from experience. My bed spray on liner is actually going to match the truck... and last.
I agree that the professionally sprayed liner is better quality and will last longer.
The cost difference for me was important though. I prepped everything well and the cost of the Herculiner was much less that getting a spray on coating done. Touch ups are no big deal if needed, and mine actually matches the truck too.
If I was planning on lining a truck bed, I would use Rhino or Linex or similar because I think it would stand up to much more abuse since its applied so much thicker. Using the roll on liner for rockers etc... is going to suit my needs fine.
