Battery options for 99 Ranger
Oddessy! That is one of the brands I saw that were listed as fitting!
what is in yours now?
The Oddesy comes up as a 59, but its in fact a 65.
its 12" long & a 59 is 10"
heres a pic of a 65 sitting on top of the tray.....
The XS power is the only true 59,
Im sure I can hack the truck up to make it work but looks sketchy
battery sitting on upright metal edges of the tray.
& now way to strap it down.
along with battery sitting 1/2" closer to hood due to sitting on tray.
I can bend the tray edges but....
The battery trays must have changed. Dimensiins for my Odyssey listed below. You could go to a junk yard and get a 3rd gen battery tray.
Im sure I cant hack the truck up to make it work but looks sketchy
A standard lead acid from one of the auto parts stores. The plan is to replace it with an AGM the next time around since I didn't have the money at the time the last lead acid battery failed.
XS Power is the other brand I remember seeing.
with the lifepo batteries available now you can get crazy with batteries.
i run 2-4 conventional group 31's depending on what i am doing.
if you are to the point of needing a new battery and have u pull yards near, many newer vehicles and vans have remote mounted batteries.
the group 31 lifepos i was recently working with for starting two small 3 cyl diesel power units and running telemetrics were wildly light.
buying one or two of those and robbing a few chrysler 300s or dodge chargers of some battery cables is a pretty cost effective way of adding battery capacity under your bed.
i ran an old ramsey for damn near 30 years and it was old when i got it. but a 130 amp alternator and 1st half life battery is plenty to run any winch...even with just one battery.... for normal pulls and duty cycles.
My bad, maybe I mis-understood..
Thought you said you were running an AMG in your rig..
Got it, youre not..
Im not liking the price of the XS, but also not liking the recent rep o the Optimas..
Going to have a conversation with the stereo installer & see if the juice is worth the squeeze at this point.
Alternator vs battery as theyre both the same price...
Ok…
My 00 green Ranger I did flatten the front of the factory tray for a larger battery. I wasn’t really happy with that. Ended up removing the factory tray when I replaced the core support and put a battery tray out of a 98 Explorer (96-01 Explorer should all have the same tray). I had to tweak the ABS mount a little and I replaced the ground stud on the core support with a bolt. Ran 1/0 welding cable into the cab for power distribution and ran 4 gauge welding cable for all of the power and ground under the hood. Also doubled the alternator power cable with a 4 gauge welding cable. The Explorer tray requires moving the horn if it’s between the plastic fender liner and the metal inner fender slightly but it fits a 65 series battery in the tray. The same battery I use in all of my other vehicles. I also replaced the factory 10 gauge ground from the battery to the core support with a 4 gauge. Amp grounds I always run back to the battery.
My F-150 has a 130a alternator and a 65 series battery. I’ve upgraded all of the wires with 4 gauge welding cable as well. Running my 8k MileMarker winch, it still draws a lot of juice. I will probably do a dual alternator system and dual batteries when I rebuild since I’m intending to fit it out with 4-5 12k winches plus be able to mount my plow.
