Ger42
I just got my Ranger 2002 3.0 V6. I am going to change plugs and wires anything else need to be changed when doing this?
Thanks
Gerry
Thanks
Gerry
Where is the synchronizer located and how hard to replace?It's not the camshaft position sensor that causes the problem, it's the synchronizer that is driven by the camshaft, and drives the oil pump, and the camshaft position sensor.
Thanks
Gerry
I'm 66 and I can't think about what I would be doing if the internet didn't exist. I will admit that thins were a lot simpler when I was young.
i personally wouldnt even wanna touch cmp as part of a tune-up why change it if it is functioning properly
i've got 123000 hard hard miles on mine and never had an issue with it![]()
Because there is about 2 seconds of warning until it fails. This results in no oil pressure and by the time you pull over the engine is "deep fried" so to speak. I would recommend changing the CPS every 100,000 miles. After all, its cheaper than a new engine![]()
