96 ranger 2wd 5 speed 160k
Cabin is very buzzy and vibrates pretty heavily at idle. Can also hear noise from engine either sounds like cam spinning and hitting rockers, or fan hitting shroud but can’t find signs of either.
Oriellys motor and transmission mounts a month ago
new double plat plugs and wires
oil change done 100 ago
no codes no overheating, oil pressure is a dummy switch but no signs of that being an issue
has an intermittent miss- almost like a misfire or ping, not specific to any piston best I can tell, happens every 3-5 seconds best witness thought a larger tremor in shifter. Again no codes
normal for old engine? Bad cab mounts? Bad brand of motor mounts? Valve train or other imbalance?
any guidance or tests I can run would be great.
