Bad Quality Bent U Bolts?
Featured Build Threads
CoconutMilkFrog
Forum Member
New Jersey
Not sure what exactly went wrong. I replaced the U bolts with new ones from Rock Auto. I tightened them evenly. Torqued to 75 foot pounds, and they bent really badly. I’m assuming it’s necessary to buy new bolts and replace them?
  • Bad Quality Bent U Bolts?
the plate is sideways. rotate it 90 degrees.
I'm not sure about new bolts. bolt stretch would be my bigger concern.
if you go to a local spring shop they take a straight rod, bend it, then cut new threads.
I agree with PJ. Your plates are oriented wrong. Rotate them 90 degrees in the horizontal plane. See photos below. I would recommend new u-bolts.you may not get these straightened and they have been stressed weirdly.
As opposed to what PJ said, most spring shops I have experienced have an assortment of u-bolt rods already threaded in different lengths. It's usually a rolled thread instead of a cut thread. Rolled threads are stronger. They just calculate the length of stock they need to make yours. Then put the stock in a bender.
Featured Ranger Based Vehicle
