4x4RangerGuy
- Aug 7, 2007
- Age
- 40
- Newton Highlands, MA
further more, if there is shit that big breaking lose, or kinda floating around in there, then the trany is already on its way out. Flushing a trans does NOT hurt it. Its not being blasted with high pressure cleaning fluids. Its juss getting some clean oil circulated through it. And no, flushing does not help with the oil in the torque converter, but most auto/light truck converters have drains. Every converter used in large applications has a drain, but is seldom used for some reason. Most likly its from people talking about the ATF monsters lol.
I have yet to encounter a light truck so far that has an OEM drain plug on it. I've installed a couple though.
I understand how hydraulic pumps work. I don't know the specific part or what its called where it gets stuck, but when I received my pump back (after requesting it out of curiosity) there was sludge (a mixture of clutch material) caked onto said section. Seeing as fluid was moving through it, I could only imagine how much harder this must have made it. Now, why after 100 miles after flushing would the tranny just shit the bed? It had NO symptoms (slipping, hard shifts, etc.). I put it into gear, went about a mile and it blew up. Usually a transmission failure comes with symptoms. Mine had none. I attribute it to flushing. Also, shortly after flushing my friends' transmissions (again, old Fords and Audis), they experienced slipping and eventual failure. I know how to flush, even on Audis which require a special tool to refill the pan.
I don't work with transmissions because they're finicky. I send all my major work to my local transmission rebuilder. I do flushes all the time, especially on the Audis and VWs the salesmen buy to resell. However, on older vehicles, my experience has been mostly negative. I don't offer a warranty on flushes for older vehicles because they always come back with problems.
