B2 Fuel Lines
abritt87
Hey Guys! New to the forum. Currently working on a 88 B2. Just finishing up the fuel system (hopefully). New tank is in, new in tank pump and sending unit, new under the door pump, new filter. My issue is that when the old tank was dropped out, the fuel line was rotted and broke. So now I need new fuel lines from the under the door pump back to the tank.
Where can I get these? I dont see it as a Ford part, nor does anything pull up at any parts store. When I tried to pick up 5/8" fuel line at NAPA, the only thing they had clearly stated "Not for fuel injection systems."
Any direction would be greatly appreciated. Would love to get this hooked up so I can see if I am going to need new injectors as well. Thanks guys.
Bronco Graveyard has the lines that connect to the tank with quick connect on them. I don't know where to get the rest of the lines of that doesn't do it. It's been a while since I looked at them, I think they are 18-24 inches long.
Arent those just generic Needa or Dorman repair lines? Would really love to replace the whole lines without spending a ton but that may be inevitable. Thank you for the suggestion!
I don't know, give them a call and ask, they've been helpful to me me in the past.
Dorman has all of the parts you need, as well as the nylon fuel line in 10 and 25 ft lengths. The barbed connectors suck, the push in connectors rock, just sayin'
