axle wont slide out of carrier *HELP*
Have tried applying a little heat? Just asking cause I didn't see it mentioned
sent while I should be working, or fixing something,,,
you should be able to pull the pumpkin with the drivers side axle shaft still in it, as long as you pull apart the passengers side shaft at the slip joint. then you can get it on a bench and work on it.
