nfussner
- Feb 1, 2016
so after hydrolocking my 3.0, i replaced with a junkyard engine.out of an automatic truck. first thing noticed was a no start without manually jumping the solenoid. found the problem to be an open circuit from the clutch switch to the new auto trans harness and spliced a couple wires and fixed it. however, my speedometer doesnt function now? nor does my low range 4wd??? any ideas? truck is a 96 b3000. wire colors in my new at harness do vary from those typically listed, as do they with the frame side of the harness
