Auto hub diagram...possible missing parts
puredreamz
anyone have a diagram from a repair manual for a 95 ford ranger XLT with automatic locking hubs.
I need to see the assembly, i think some joe blow mechanic put my brakes together with missing parts.
how would a diagrahm of the hubs help you asses a brake problem? If you truck is equipped with the sliders then there is;
1 slider at the top of the caliper
1 slider at the bottom of the caliper
1 caliper
1 left pad
1 right pad
a little flexy plate on the back of the inside pad and spring clip on the outside pad
Oh yeah almost forgot, you should have some brake fluid inside the caliper, the hub slips back on the rotor then the wheel. Unless the mechanic changed your rotors you shouldnt be missing any parts.
If he did change the rotors then you should have
1 wheel bearing nut
1 retention pin to prevent the wheel bearing nut form turning
1 spring loaded toothy thing to engage the auto hub
1 auto hub cover
If things aint working its probably because the shitty for auto hub broke, swap to manuals.
