AttemptingToBeAMechanic
- Oct 28, 2016
- Automatic
I spent a little time studying the diagram today. Here is what I have figured out. From what you are saying, it sounds like your internal governor module is faulty, unless you can find some wiring shorted to ground somewhere.
I looked over this diagram and the notes as well. Am I reading this correctly that when the MFS is in the park position there should not be any voltage between DG (Dark Green) and ground? I always read about 12V here (reading from the negative battery terminal and the socket for the DG wire that attaches to the govenor). Jiggling the wires around does not make a difference.
