Yeah the 6F35 is a money maker for sure. At least the OEM parts aren’t priced that bad”YET” LOL!
You know, I have the exact opposite opinion of it for the exact same reason.
You run your own independent shop, every job is cash for you. I only overhaul them under warranty. I get 7.4 hours to R+R, 5 hours to tear down, inspect, flush torque converter and overhaul unit. That includes time to figure out parts prices and submit my cost-cap and prior approval papers.
And they are an expensive transmission built out of cheap parts. All the individual parts inside the trans don't quite equal the price of a unit.
I just finished one Friday that I kind of expect to see back before too long. Pump was dying at 115K. Couldn't find anything wrong in the valve body, and did a soft overhaul, all clutches and seals, everything was in spec, new pump, and it was shifting a little firmer than I would have liked when it left.
I told the customer it was still learning (hoping that was true) and that unless it did anything truly odd like slamming into a gear or slipping really bad to give it a week or so to figure it's life out.
Next one on my agenda is calculating 1st gear as a 16:1 ratio.
