What I have now... (a four-letter word starting with S). 4" rough country kit on the TTB. 31" tires.
Really just want to flex it, and in the future run 35's. From what I can find the Duff setups are about the best bolt on money can buy. For the nominal $2,400 or so shipped to my door with everything included (the stage 3 deal-o-meal, and steering stabilizer).
Or have to buy beam brackets (duff or skyjacker), coils, arms (definitely duff for the heims), shocks, brake lines, pitman arm (skyjacker) and end up spending just about as much money in the end. Doesn't help my coil buckets are about trash too.
I've read in the past that the most you can run on a D35 TTB is 35's before you start breaking things. Is this true? I knew a guy who ran 38's and broke something about every time he went off road, but he also drives like an idiot and is more than happy to romp it into an unknown puddle or what not.
Then there's the SAS. Locally, a '77 F-150 D44 is going for about $2-300. I'm having a hard time figuring how much it'll end up costing me in the long run (including a percentage for effort). Mostly figuring all the parts needed... coils, buckets, shocks, t-bar mount, steering setup, likely replace the wear parts on the axle (bearings, ball joints, brakes), machining costs (to shorten the shaft), rims, rear shafts or lug adapters...
The build threads I've read all assume a lot of information or leave out details. Not that I couldn't figure it out in due time, I'd like to put it on in a weekend. A SAS with all the figures and parts known and bought can pretty much be assembled on the bench and dropped right in, or a kit for the TTB can be bolted right in too, then a trip to the alignment shop.
Am I missing something or what?
