lorenambrose
Below is the recorded data from a 2003 Ford Ranger Edge 3.0 FFV V6 2wd. The truck seems to run great but idles like crap. The idle is rough and seems to have a miss. This data is after new Autolite APP103 (factory equivellant) sparkplugs, Autolite Professional wires, Cleaned MAF, Coil is 2 months old and was also metered out OK, seafoam thru vac line prior to plug change, and I have run Gumout Complete Fuel System Cleaner for two consecutive tanks.
I can not find any vacuum leaks and the vacuum holds a pretty steady 18-18.5 in/hg. The upper intake gaskets were recently changed and made no difference at all.
The battery and alternator are also new.
ALL the data is at idle with the engine up to operating temp and the transmission in park.
Recorded Data
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 729
CALC LOAD % 19.2
MAF FLOW GR/SE 4.26
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -1.0
LT FTRM1 % -1.0
ST FTRM2 % 0.8
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % 0.0
O2S12 V 0.605
O2S21 V 0.075
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 716
CALC LOAD % 19.6
MAF FLOW GR/SE 4.20
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -2.2
LT FTRM1 % -1.0
ST FTRM2 % 0.0
LT FTRM2 % -2.2
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 0.8
O2S12 V 0.605
O2S21 V 0.175
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 1 Time 0.9
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 703
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -3.4
LT FTRM1 % -1.0
ST FTRM2 % 0.7
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.095
ST FTRM11 % 0.0
O2S12 V 0.600
O2S21 V 0.610
ST FTRM21 % 0.8
MIL DIST mi 0
OBD2 STAT CA
Frame 2 Time 1.6
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 717
CALC LOAD % 19.6
MAF FLOW GR/SE 4.20
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % 0.0
LT FTRM1 % -1.0
ST FTRM2 % -2.2
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.665
ST FTRM11 % -1.0
O2S12 V 0.600
O2S21 V 0.660
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 3 Time 2.3
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 722
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 192
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % 0.8
LT FTRM1 % -2.2
ST FTRM2 % 0.7
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.080
ST FTRM11 % 0.7
O2S12 V 0.600
O2S21 V 0.665
ST FTRM21 % 0.8
MIL DIST mi 0
OBD2 STAT CA
Frame 4 Time 3.0
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 707
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 192
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -3.4
LT FTRM1 % -1.0
ST FTRM2 % 0.0
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.135
ST FTRM11 % 0.0
O2S12 V 0.600
O2S21 V 0.090
ST FTRM21 % 0.7
MIL DIST mi 0
OBD2 STAT CA
Recorded Data
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 729
CALC LOAD % 19.2
MAF FLOW GR/SE 4.26
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -1.0
LT FTRM1 % -1.0
ST FTRM2 % 0.8
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % 0.0
O2S12 V 0.605
O2S21 V 0.075
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 716
CALC LOAD % 19.6
MAF FLOW GR/SE 4.20
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -2.2
LT FTRM1 % -1.0
ST FTRM2 % 0.0
LT FTRM2 % -2.2
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 0.8
O2S12 V 0.605
O2S21 V 0.175
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 1 Time 0.9
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 703
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -3.4
LT FTRM1 % -1.0
ST FTRM2 % 0.7
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.095
ST FTRM11 % 0.0
O2S12 V 0.600
O2S21 V 0.610
ST FTRM21 % 0.8
MIL DIST mi 0
OBD2 STAT CA
Frame 2 Time 1.6
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 717
CALC LOAD % 19.6
MAF FLOW GR/SE 4.20
COOLANT F 190
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % 0.0
LT FTRM1 % -1.0
ST FTRM2 % -2.2
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.665
ST FTRM11 % -1.0
O2S12 V 0.600
O2S21 V 0.660
ST FTRM21 % 0.0
MIL DIST mi 0
OBD2 STAT CA
Frame 3 Time 2.3
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 722
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 192
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % 0.8
LT FTRM1 % -2.2
ST FTRM2 % 0.7
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.080
ST FTRM11 % 0.7
O2S12 V 0.600
O2S21 V 0.665
ST FTRM21 % 0.8
MIL DIST mi 0
OBD2 STAT CA
Frame 4 Time 3.0
MIL STATUS OFF
ABSLT TPS % 17.2
ENG SPEED RPM 707
CALC LOAD % 19.6
MAF FLOW GR/SE 4.26
COOLANT F 192
IAT F 69
IGN ADVANCE DE 18.0
ST FTRM1 % -3.4
LT FTRM1 % -1.0
ST FTRM2 % 0.0
LT FTRM2 % -3.4
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.135
ST FTRM11 % 0.0
O2S12 V 0.600
O2S21 V 0.090
ST FTRM21 % 0.7
MIL DIST mi 0
OBD2 STAT CA
