adsm08
Senior Master Grease Monkey
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
I always thought the E4OD was designed around the C6 gearset. Of course, pretty well everything else becomes different.
Back to the OP, the E4OD would be pretty much irrelevant for a Ranger V8 swap simply because of it's size. I'm still contemplating transmissions for my 351W swap and the AOD is the easiest because the only OEM 351w/5.8l EFI computer with controls for an electronic transmission you will find will likely be for a 5.8l/E4OD. It may be possible to use this computer with a 4R70W. The only other option is an external controller.
The 4R70W is too computerized.
He is wanting to get away from computers.
