88mudder
- Aug 26, 2007
- Age
- 36
- waterford michigan
i assume you have reverse....do a few slams and see if it pops.
go for rev @ 1800 with the brake on.
then get some black magic and add it to the fluid, sounds like its sticking.
hard to say, i would really need to see it. 100 psi is too much with the engine at idle in any case on the other port, only time it should be over 75 is in reverse. even then 100 is pretty high.
seems the governor may really be stuck, it may be worth the effort to pop the case off and clean it up. but likely its the pr valve or tv valve thats stuck. you have to drop the pan for them bastards.
Yup i have reverse and it works perfect. Thx for the tips
