avid
- Nov 10, 2018
- Nebraska
- 4.0 V6
- Automatic
The 4.0 is a bit different than most OHV engines in that the pushrods are solid and don't send oil through them to the rockers. The rockers are oiled by separate galleries from the lifters. The plastic cup is there to retain a bit of oil to keep the bottom of the pushrod lubed.
Usually the wear happens on the top of the pushrod at the rocker, but since lifters are available and it's a roller setup I'd probably replace them.
Four of the twelve lifter cups were no longer attached. I don't know if they were old ones or cheap replacements. Also the valve stems are different lengths. I haven't dug up the specs yet but I suspect that's not good either. The engine was rebuilt by PowerTorque and only has 35K miles on it but is about 7 years old now. I should have inspected it more when I got it rather than trust.
I think I'm going to try to clean and use the lifters that came out of the Mazda engine I'm replacing. Found an instructional video on youtube for that:
