bduke23
I want to change my tranny fluid to finish off my new clutch and slave. I heard lots of good things about Royal Purple Synchromax, but at $18 a quart up here its a bit too expensive. Has anyone used any of the Mobil 1 synthetics? If so which one? I saw on their site that there is a synthetic, and also a multi vehicle atf.
I have also read that Mercon V doesn't work too well with the older M5OD's, so I'm not sure if Mobil 1 will cause the same problems or not.
Any other synthetics I should think about? Also, would it also work in the t-case?
