So I put some Lucas stop slip stuff in and now on cold mornings it hesitates to go into drive. Like if you are driving and stop at a stop sign and go to take off there is hesitation between hitting the gas and actually going. Not sure if it is because of how thick that Lucas is or not. I only used about 1/3 of the bottle so I didn't think it would cause that much of an issue. Just wondering is anyone had this same issue. or if they did have this issue if it went away as the Lucas got worked into the fluid. Its only been in the trans for about 2 days now and I only noticed this at first start up on cold mornings. Doesn't do it after it warmed up.
Transmission additives do 2 things, they swell gaskets and seals to prevent pressure loss and they have a friction modifier that helps clutches and bands grip better
All automatics run on pressure, pressure holds clutches engaged or disengaged, and holds bands in place, bands are "brakes"
Reverse requires the highest pressure, 150+ PSI, so if there is a pressure problem it is most likely to show up first as slow to engage reverse, and if pressure gets low enough then no reverse.
Pressure is provided by the Main Pump(Front Pump) which is powered directly by the engine RPMs via the torque converters outer case
Pressure is lost when there are internal leaks in valve seals and gaskets.
Raising engine RPMs will, of course, increase internal pressure, since RPMs drive the pump.
So if you have to "give engine a little gas" to get Reverse to engage then you have some internal leaks starting, just FYI
And there is also the torque converter
Outside case of torque converter spins at engine RPMs, and there is a separate inside part that is free to spin at its own RPM and that is what is connected to the transmissions input shaft, drive shaft.
This "free to spin" part is what allows you to stop the vehicle while still "in gear"
Google: torque converter stall speed test
These tests can tell you if torque converter or transmission might be the problem.
3.0l Vulcan engine probably has a pretty high stall speed, I would look it up, but the 3.0l makes best torque at 3,000+ RPM
I would put in the whole bottle of "trans fix", it literally can not hurt the transmission, any problems after adding it are coincidental and/or preexisting, i.e. people don't add "trans fix" unless they think there IS already a problem, lol.
