lil_Blue_Ford
Cut & Weld
⭐Supporting Member
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
Any other ideas? I haven't come up with any.
I'm thinking of going with the one I posted above, unless you came up with any different styles for me to review. I've been trying to decide if I should ask for a buckle on the hat or not. I also have been trying to decide on a background color and if the guy should be made smaller and the company name run full across.
I've been leaning towards a silvery grey color for a background, that way it will still grab attention but also match the colors of the truck. If you have any other ideas, feel free to suggest them.
Also instead of "Serving Butler, PA" I thought of just putting Butler, PA because I do work over three different counties around here. That way they know where I'm based out of. Then perhaps do something like "Quality since 1952" or the like. And put my PA license number - PA057659.
Here's some specs on the dimensions for the magnet. I'll probably order up some business cards and yard signs too since I'm almost out of business cards. I could probably just use the logo by itself for the business cards unless you want to design for that too. Thanks a ton for the help!
You can also go Here for specs on the magnets (if that doesn't work just go to http://www.vistaprint.com
Full Bleed Size (starting document size)
17.70" x 11.60"
450mm x 295mm
3098 x 2030 pixels
* Finished artwork should use the full bleed dimensions for best results.
Document Trim Size (final size after being cut)
17.30" x 11.25"
439mm x 286mm
3028 x 1969 pixels
* Please be sure to keep all text within the safe margin.
Resolution
175 DPI
17.70" x 11.60"
450mm x 295mm
3098 x 2030 pixels
17.30" x 11.25"
439mm x 286mm
3028 x 1969 pixels
Resolution
175 DPI
