any ideas for ALPINE TYPE X SETUP?amp?
teknique
Oshkosh, Wisconsin
Hello everybody! ive got a couple questions for ya all...
first i should start by telling you what i have for a setup so far. I bought a 10" alpine type x 3000watt subwoofer i built a custom 1.8 cu/ft box with a 1" by 22" vented slot port that is ported to 35 hertz!! I am looking for an amp that is best quality, best heat control and best power output for this power hungry subwoofer!
1st question: any ideas for an amplifier? im looking at either the Hifonics HFi 1500D which is 1500watts total power, and the 10" type x is I believe 500rms to 3000total power.. i am looking to wire it at either 2 or 1 ohm and throwing hopefully 1000rms to that beast!! here are sum stats for the 1500
500W x 1 @ 4 ohms
1000W x 1 @ 2 ohms
1500W x 1 @ 1 ohm
Hifonics HFi 1000D is another choice. its 30-40 bucks cheaper that the other but idk if it would do just fine.. stats are as listed:
475W x 1 @ 4 ohms
750W x 1 @ 2 ohms
1000W x 1 @ 1 ohm
also there is a Rockford Fosgate T1000-1bd and its a beast! its like 150 bucks more im pretty sure but for the money its worth it... (I AM A FIRM BELIEVER IN YOU GET WHAT YOU PAY FOR especially with car audio) here are some stats (mind you these rockfords are way underated..)
350W RMS x 1 @ 4-Ohms
650W RMS x 1 @ 2-Ohms
1000W RMS x 1 @ 1-Ohm
(birth certificate is max i believe like 1775watts rms at 1ohm)
if anybody has any good intell or ideas or maybe for amps i didnt even list i would very much appreciate the help! thanks for taking the time!!
I'm have been doing a ton of research and just ordered a JL Audio 1000/1. You might want to take a look at it. Your sub is 4 ohms and It puts out 1000 rms watts even at 4ohms. I got mine on ebay for a little over $300 slightly used.
