Acadist
- Mar 17, 2013
This may sound silly but.......Does the donor motor you pull the components need to be a 2.8 (I have an '85)? I found a '78 Mustang II with a 4 cylinder, the module looked like the pictures I have seen and it had a 2 barrel carb. The distributer was missing, but would a distributer from a 4 banger work on a 6? I also saw a duraspark module unit in a truck from the same time period but looked different and had a straight six, it had a label that said Duraspark, would that have worked? I felt bad not grabbing it, cars from the late '70s are getting hard to find, but did not want to spend the money if it would not be the right components
