http://www.therangerstation.com/tech_library/diagrams/Ignite1.GIF
Is that the computer connector all you need is key on hot for the coil the two wire connector is for the module you do not need to mess with the chassis harness at all the starter wires do not need to be touched. Where is that connector located under the hood
Below the brake booster. 2 wires are for engine sending units. 2 wires are to the alternator. Red arrow above points to Brown wire with Pink stripe hot start wire. Connector is in bottom right of this picture. Can someone with a 1983 or 1984 let me know where these wires go?
For
