vpcoded
Took the truck 4wheeling this week end A long hard steep run then a mud filled valley a lot of fun and new battle scars for the truck. This is not the problem but I would have made a lot of ranger owners very proud of how capable the truck was or very angry for the complete disregard for the body and well being of the truck ha ha. {Still have power loss so all I can do with the truck is off-road and I'm getting my money worth wlill have some video footage of the next trip stay tuned}. OK OK OK here my problem due to the power loss and testing things ECT I have kept the dizz not all the way tight in place so I can mess with the timing. Well I was hitting a straight up area trying to pop the front tires over and crawl on up and on the fourth attempt got the tires up and over and this damn truck was pulling it and I couldn't believe it then bam power loss and rolled back down. truck would not start I got out and moved the dizzy and it fired up and I watched the dizzy slowly spin backwards and the truck died and would not restart. I had the truck pulled home pulled the dizz out and the lower half of the gear lost some teeth like it jumped up and hit a few times the top have and areas of the bottom are ok. This is a new dizz. I guess the questions I have is can I use this as is I would think so if it makes contact with the whole gear as the top is not damaged at all. also the gear that drives this inside the motor because I know I'm going to get some you need to replace the dizz gear and check for metal in the dis shaft area and the gear in there as well how would one go about reaching that pull the motor? if I rotate the cam and inspect that gear all the way around and it seems fine as it was the one doing the damage to the dizz gear I hope what would be the best way to find the metal that came from that gear? Run an extending magnet down the shaft the do an oil change and flush down the diss shaft as well would this be enough?
BTW thanks guys for all the help on the RPM loss issue I am still working on that I will get some video footage of how it runs when I get it going again I have it taken apart do to this dizz deal and not wanting to ruin it but wanting to throw it together by this week end to hit the trails again meet some other 4x4s out here at the lake this week end and looking at getting a party to go.
