Aftermarket power windows
Jim bow
Law Enforcement
B809207ang
Has anyone installed a set of those Universal Power Window kits?
Yes, and no, they were more work that switching to factory power windows
As far as the work goes........
You have to remove door panels
Then remove factory manual window crank/regulator, riveted so you need to drill them out
And run 2 wires out of the door for 12volts and ground to operate the electric switch/motor
The above is exactly the same for universal or factory install
Universal requires you to drill, mount and cut, then re-cut, lol, so it matches door and window perfectly or it will bind up or not go up or down all the way
Its CUSTOM work
One size does NOT fit all :) at least for the two different ones I tried, these were in vehicles that had NO power window option, so no factory option
Factory power window regulators are already setup to fit, you do need to drill 1 or 2 more holes to match but 2 holes are already there from manual regulator
And that's pretty much it
So look at the cost of factory used, vs universal new
Also replacement parts if there is a problem a year or two down the road, that's were factory is best, lots of Rangers still running around, lol
You can use factory door panels and switches with either kind, just FYI
If you want drivers door to also have a switch for passenger door window then you need to run 2 more wires from drivers door to passenger door
But only need the 12volt wire at passenger door, as the 2 extra wires include Ground wire for switch on passenger door
So 4 new wires in drivers door and 3 wires in passenger door
The 12volt needs a 20amp fuse and can be full time power if you want, they won't drain battery unless you use them alot with engine off, lol
Or you can use a relay that's activated with key on
You don't need any factory wiring, but getting the connectors for switches and motors makes it easier
If you're looking at adding power windows to a truck not equipped, @RonD nailed everything perfectly.
I installed aftermarket accessories, years ago, including several types of add-on power windows. If I feel the need to convert one of my own trucks from manual windows to power, the only way I'd go is to transplant all of the needed factory parts.
Aftermarket window kits never work as good as factory power, they will end up breaking, and then getting spare parts will be very difficult, likely impossible. Parts for factory windows have good availability now (even on the '83-'94 trucks I drive), and future availability will still be better than finding aftermarket kit parts.
