JoeyB
- Jan 19, 2010
Ok, I've been doing a lot of reasurch and trying to decided which set of heads to put on my 1991 302HO. I've got a Weiand intake, 600cfm holley, stage 1 tick flow cam, and an MSD ignition. I have come to the conculsion that the AFR heads are probably the heads of choice for me. You can use your stock rocker arms (upgrade later when you have more money...
), stock valve covers, and still get around 50 to 75 more HP. Anyone using these? Do you like them or not? I'm not trying to start the classic head war (which heads are better) but more on the lines if your using the AFR 165 heads do you like them or not? Thanks for your input.
