Adapter HELP lol
Durham
NC - USA
Vehicle
Drive
Stock?
Ok so here goes my first post. I came upon a stupidly low price for a set of AT3’s, 235/65/r17 mounted and balanced to set of 2022 maverick steelies. Tires are nearly brand new, wheels are too. I like the look of the steelies, and I know I will have to run adapters to go from 5 on 114.3 to 5 on 108. Does any body have any info on whether they will fit. It is a 2wd, stock ride height. I am completely stupid for some reason when it comes to backspacing and all the figurin’ that goes into wheel swaps. Its like Greek to me. And i dont understand Greek one bit. Any help would be appreciated. Thanks!
If you already have them, then jack the truck up and stick them up in there, just to see how it's going to be. You will not be able to mount them, but should be able to get them in the ballpark and see how it looks. It's difficult to think in 3 dimensions when fitting something like this, so the best way is to do it manually. You should be able to simulate the fitment very close, since your spacer is going to space the wheel out beyond the stock studs anyway.
You are going to need about 1.25" or 1.5" thick adapters to make that all work. Get hubcentric ones so you know the wheels get mounted concentric to the hubs. And don't get the cheapest crap you can find - search for good quality ones.
Ive had great experience with Coyote Racing wheel spacers. This is my second set I've owned. Ran the first set on my Sport Trac so I could run some Mustang wheels. Ive had this set on my 2020 since 1100 miles. Im at 90k with several towing and offroad miles included. Just if you run wheel spacers check that they are torqued down every tire rotation. I actually use some lock-tite on mine.
Thank you for the responses! I was thinking the adapter was going to have to be about 1-1/2” to get fitment with no rub just from some crude measurements and my atrocious attempt at mathing 😂. At least i wont have to shorten the stock studs!
