adaptation a4ld
Momohenri
Hogne Belgium
Hello everyone, I found a good a4ld gearbox for my Bronco II 4x4 but it was a ford scorpio 4x2, the rear axle (output shaft) is too long, I think I put the axle of my old gearbox. do you have to remove everything from the front or can it be removed from the rear?
The output shaft on the 4x4 will need to be removed from original transmission and installed in replacement transmission which requires complete disassembly of both transmissions. Not a simple bolt in repair.
Good luck
Brad
thank you, is there a particular difficulty ? , I saw a video of a reassembly, apparently the hardest is the band adjustment
You’re welcome, not a particularly hard job as it’s taking parts out and setting them back in the case. Just quite a few pieces that has specific assembly procedures that can be missed it not familiar with transmission repair. I would suggest getting a workshop manual and get an idea of what to watch out for.
Good luck
Brad
You have to tear the transmissions apart to swap shafts, may as well rebuild the old one....and I highly doubt you found a good A4LD, there never was one made they've got to be the worst transmission Ford ever came up with given the huge number of failures.
Rebuild or have a shop rebuild the one that was in your Bronco 2 and be done with it, and just give them that other transmission.
