ac/radio won't turn on?
Pony
Phoenix, Arizona
So I decided to put all the a/c stuff back in and now when I try to turn them on they won't.
I have everything connected I don't know what to look for any help? thanks
So i checked the fuses again pulled all the ac stuff out and still radio won't work? any ideas on what to check next?
Did you verify with a voltmeter that you have power to the radio's electrical pins? Here's my 1997 pinout, which I assume matches your 1992 Ranger pinout...
Just checked em power to the red and checked the ground wire, it's fine. Still doesnt turn on and also rechecked the fuses all still fine.
I just rechecked the gray ones two of them are 12v so what can I check next? I am stuck
Well found out the radio was blown, tested it in my uncles truck who had the same deck so thanks for the help cvar I appreciate it :D
