twitch
how and what will i need to do/need for this to be done and i looked in the tech libary but i couldnt find anything.
the 4.0l pump is working for you?I find just packing a squirt bottle full of ATF and a T inline with the intake on the compressor works wonders, give it a shot on start up and its good to go. An oil water separator on the outlet is a must.
i diden't think it was,were you talking about atf in the 2.9l pump?
EDIT: a york 210? is that a serpentine app.? sounds good
you probably want to run a manual switch if using the stock a/c pump otherwise it will burn up when you turn on your defrosters... i found a inline air tool oiler at harbor freight for cheap ( like everything else) i'm gonna put that infront of the intake and add a water/oil separator on the outlet side... looking for suitable tank at the moment
