- Apr 30, 2024
- Moncton NB
- 3.0 V6
- Automatic
This is what I was suggesting a couple days ago, a bit of a pain but jumper the left side harness wiring onto the right side sensor. Then you'll know if you have a wiring problem... It's a quick and dirty test that requires small alligator clips and some wire.Swapped sensors. Still no input. Is there a way to test the connector that the wheel speed sensor cable plugs into? I know it's a 2005 Jag, but this was built when Ford owned Jag and some things interchange.
Looks like I can get a new connector and cut off the old one.
