James86
- May 6, 2009
- 55381, Minnesota
2012,
- Automatic
- My credo
- WHY DO I KEEP BUYING DODGES?!?!?
My ABS light has been intermittently coming on and off recently on my 1999 Ranger with four wheel ABS. Cycling the key will make the light go out, but I have a scan tool that can pull ABS and transmission codes so I hooked it up when the light came on again and it gave me:
B1233
B1234
The reader explained the codes as the front left and right ABS sensors not responding. I was curious first off if these are standard coded (never pulled ABS codes before), and whether it's possible both sensors would fail near simultaneously on a 15 yr old truck, or the problem may lie somewhere else.
The scan tool I have is an Innova 3130c Scantool w/ ABS.
Tried searching on here for the codes but came up dry.
B1233
B1234
