ABS code 11, need wiring help
Stangman92
Solid Axle Swap
NW Chicago
ABS code 12, need wiring help
I have an ABS code on the Ranger, its code 12. From searching i found its probably from the master cylinder float switch. The harness was dryrotted and the wires fell out. I would like to just put the 3 pins back the 3 switch connections, but i need to know the wiring order. A pic would be great. Or would it be better to connect the 2 colored wires, and ground the black wire? Thank TRS!
