John Smith
- Jan 17, 2010
good input...
Glad you chimed in on the vapor-lock problem. When i change to my other carb, i want to re-route my fuel line and change the inline filter situation to a visible one. I happen to be in a milder year round climate, but vapor-locking still has been an issue during the HOT MONTHS of our summers driving different older cars when carbs were the norm.
Adding an electric fuel pump partly helped sometimes...
I have been trying to keep the mechanical pump in use on this Project B2..I'm not sure it's absolutley necessary we'll see..
Do you run an electric pump?..if so what brand/type..? an do you use a return style regulator if any?...if you don't mind the questions..
I usually prefer the KISS method...(Keep It Simple etc..) but i have been considering using an electric pump if nothing else than a small one to help prime from the rear tank..
One thing that isn't discussed much on this forum is carburated fuel management..surprising since most guys that go to carbs..generally have to engineer something in the way of reliable fuel delivery from changing the different fuel lines etc that are present depending on which donor year their project car happens to be...I suspect vapor-locking is more of an issue than we realize..especially for some in the warmer climates.
FUEL LINE ROUTING and MANAGEMENT...good topic...
Here in AZ hot fuel vapor lock is always a problem in the summer. On my project carburated Ranger, the fuel line has been rerouted to run next to the AC vapor line and then wrapped in header type wrap the keeps header heat out of the engine compartment. I have access to thermocouples and a data recorder, I had a thermocouple on the fuel line skin temp at the fuel pump outlet, I observed that when the fuel line skin temp would get around 200' that is when the engine would start vapor locking in city traffic. So that is when the fuel line was routed next to the AC vapor hose, the one that runs over the top of the radiator. but....it would still vapor lock after a 20-30 minute heat soak, like driving through traffic to the parts store, go in the store do business, then do a drive away. The engine had a bad sag until the cooled fuel got into the fuel bowl.
As far as getting rid of the cold air system, never. maybe disconnect it in the winter, but there is added power and fuel economy to be had even with the factory stuff. After working in the automotive testing business for over 30 years, I have learned that the factory does not add anything they have too unless there is a good cause....
As soon as I get my Ranger back from daughter I will post a picture of the fuel line.
Why would I put a thermocouple on a 83 Ranger? cuz it what I do...It has been a hobby since I was a teenager...
