A4LD Torque Converter Removal -- Is there an easy way?
e21pilot
My 1992 extended cab 2WD Ranger is running and driving fine but the transmission is making a whining noise in the forward and reverse gears whenever the lock-up is not engaged (low speeds only).
After changing the fluid and filter, I still have the same noise. I think it must be the converter that is going bad because it only happens when the converter is torque multiplying.
I am wondering if the converter is easy to replace myself? I could probably unbolt the transmission an push it back a bit to achieve this but pulling the whole transmission is more work than I want to get into.
Is it possible to re/re the converter with the 2WD transmission still in the truck?
could be a loose filter. or plugged up.. low fluid...
i would say the pump could be getting ugly
When was the last time the bands were adjusted?
It would be possible to drop the trans down and back far enough to do a torque converter, but it wouldn’t be fun, the TC isn’t exactly light and you need to pre-fill it with fluid, then when you carefully slide it in so you don’t damage the seal, you have to spin it until it seats
if you think pulling the trans is too much work.
you can not swap a converter
I should have provided more details. The transmission was rebuilt two years ago and only has about 15K miles on it. I run Amsoil full synthetic ATF in it and keep the level at the top. I have done some heavy towing with it but If I remember correctly, it didn't make an noises after I used it for towing. The noise just started happening on its own. The noise sounds a lot like a Ford power steering pump whine when their is air in the fluid or the wrong fluid was used. I am pretty sure the noise is in the converter because it only makes the sound when in the driving gears and only when the torque is not locked up.
