broncobuckinaround
- Sep 24, 2012
didnt have ttc lock up in 3-4 until i replaced the solenoid. i knew that was the problem
but now when when it shifts it shifts hard and vibrates. like when you driving in 4th with a manual at 25 mph. it vibrates.
i changed the fluid and flushed the torque converter. either my bands are loose or the modulator is damaged. i do know there is a small vacuum leak in the line to the modulator but i was sure if that could be my issue. i wanted to find out here before i removed my exhaust to fix it.
