97fordrunner
So I had my A4LD out and went thru it and did a once over replacing seals and clutches. I did that cause the guy I got the truck from said he blew a tranny line and ran it out of fluid, I checked the lines they were ok so I figured that on of the slide on lines popped off and he re-installed it and then topped it off. Well I put in a new TC and the above items reinstalled it and have nothing. When I was adding fluid I noticed that a small puddle formed underneath and found it to be coming from the breather which has me confused. Then After adding 7 qts(which the book says it the whole system takes 10) I ran it for a little bit putting it thru gears and then shut it down to see if the level had dropped and it hadn't moved at all it was still way up the dipstick. I didn't take the pump houseing apart as from what I read unless you have all the tools and knowledge leave the pump alone so that is what I did. Is that probably where my problem lies? I also did not replace the servos which I know is a no-no but the parts store did not have them on hand.
I am stuck for now, and really contemplating swaping in a M5OD but the reason I bought it was to give my wife something 4wd to drive
This just in I found a 91 exploder near me on the great CL and bad motor but a good M5OD and axles, would the pedal assembly and master cylinder and other suck items bolt up to my '89 BII? Thanks again guys for taking the time to read my post and thank you in advance for any help.
