a4ld all gears were like it was in nutral for a minute then back to normal
stealhorse
Hi I was hoping someone can shed some light on this problem. I was wheeling it all day, then before I decided to go back home, I tried climbing this ten foot tall steep incline just like I did earlier a couple times I went half way up then back down for a moment then went up again then all of a sudden the tran. let loose like I put it in nuetral. No revers or forward gear. So I turn it off real quick after backing down the incline and testing the gears like I said. I looked under the truck and the linkage seemed to work properly. I didn't notice any leaks. So I fired it back up on level ground and it shifted fine in all gears, and I drove back home fine. I have a trans temp sensor and external cooler. It said it was normal temp. So. I hope someone might be able to give me some possibilities on the problem. It seemed to have something to do with the incline, but it didn't do that all the other times I was climbing up stuff that day, but it was one of the steepest. I thank anyone who replies in advance.
