A Coil Spacer Question
Measure how much thread length is sticking up above the nut. That'll be exactly how thick your spacer can be and still have 100% thread engagement on the nut.
Well there done. I made some spacers at work and hope they work the are made from 3" stock milled down to 1.125" thick and have a .562 thru hole and a 1.375" counter bore on the bottom. Not sure on when I will get to install them but at least there made. If anyone thinks there might be a problem with them before I try to install them let me know thanks.
[/IMG]
Looks pretty good....As long as the bore on the bottom is deeper than the height of the nut on the stud then that will work perfectly.
I tried to get info on how deep to make it but never a exact size. So I just made 2 sets one pair .500 deep and one pair .300 deep. So they should. :headbang: Well now that what will be the easiest way to get this re-aligned? Do i want to take to a alignment shop before ordering the correct parts or do some places that you guys know of already have what i will need to re-align?
Those spacers look nice.
I think the nut is right around .5" tall IIRC. Being milled too deep isn't going to hurt anything, maybe go ¾" deep on the bore if they don't clear.
As for the alignment, the proper way to do it is to have the frontend checked on an alignment machine using 0° bushings to see how far off it is, then install the correct offset bushing to make up the difference.
However a lot of guys go out and buy a set of 2° bushings ahead of time and just stick them in in whatever position gives them the correct camber. There's a good possibility this will result in your caster being incorrect however.
If you want to get the bushings beforehand, I would suggest getting the two-piece fully-adjustable ones. These can be dialed in to whatever amount of offset is needed.
Your best bet would be to buy dual adjustable bushings. They allow you to adjust for camber/caster separately, and can be re-adjusted if you decide to go higher...In essance, the last bushing you'll need to buy. They have adjustment for up to ±4 degrees.
Ingalls 594, Specialty Products 24180, Moog K8986, Spicer #6122025, Napa NCP 264-3950, Superlift SLF-1120, pick your poison.
Secondly, eye it up and adjust it as close as possible, and take your truck down a dirt road or something to help settle the springs before taking it to get an alignment.
Junkie beat me to it...
