kimcrwbr1
All I am saying is you should not operate the system without the safety device in place how does that make me a hack. Too high of pressure can destroy the compressor then you will be doing it all again. Check the pressure at 3000 rpm and you will see what I am talking about. If you dont know how much refrigerant is in the system by weight get he low pressure switch working correct so when you unplug it the clutch dont cycle the compressor. then pull some of the refrigerant out into a empty container while the engine is running and the a/c is on add juice to it until the compressor cycles. It takes a few minutes for the system to stabilize then add juice slowly a little at a time then let it blend until you get what the sticker under the hood specifies. If you have a good thermometer check the delta-T that is the difference between the air going into the blower and the air coming out of the vents. what happes with too much refrigerant is the liquid stacks up in the condenser in front of the radiator and reduces it`s ability to transfer the heat out of the refrigerant. Heat transfer is done in a vapor state and as the heat is pulled out of the refrigerant it turns into a high pressure liquid. That goes through the expansion device (piston or expansion valve) and flashes from a liquid to a low pressure vapor and absorbs the heat from the cab in the evaporator and takes it out to the compressor and turns it into a high pressure vapor that goes into the condenser in front of the radiator where the heat is pulled into the atmosphere and condenses the vapor into a liquid that is stored in the receiver. Heat always transfers from hot to cold. You are not adding cool you are removing the heat through the refrigerant. When you put a beer in the refrigerator you are not adding cool your pulling the heat out of it.
