Ok, so...
Got the ground strap mounted for the intake/head -> firewall.
Found where the cab -> frame ground is, next to the plastic harness bracket below the driver door, just gotta use a self-tapping screw to get it secure (the old strap, what's left of it, is still on the cab, rusty screw head, so I'll have to install nearby).
I have yet to find where the bed -> frame location is... don't see any old straps/remnants. Although the previous owner grounded the white wire for the previous hitch plug to the rear of the bed (driver side, just below the tailgate, behind the bumper)... wondering if I could just use that hole and self-tap into the frame.
I had read somewhere, somewhere, that the bed ground is on the passenger side somewhere. That may or may not be for my year though.
I read an old thread (
https://www.ranger-forums.com/general-technical-electrical-18/ground-wire-locations-144340/ ) where RonD went into some detail as to the ground locations. This particular thread OP had the same year Ranger as me.
RonD:
"There are 6 locations to check though
Battery negative terminal, never assume, lol
Starter motor bolt, this should be the other end of the battery cable
Head to firewall ground strap, computer and dash ground
Block to Frame ground strap, tail light ground, also fuel pump/gauge in some
Battery to Rad support, usually a smaller 2nd wire on battery terminal, this is for head lights.
Rad support to fender well"
I'm good on most of these he listed. However, I don't know where the block -> frame ground strap would go. Also wondering exactly where this radiator support -> fender well would be (I don't have it currently). I noticed he didn't list a bed -> frame ground. I've read that this grounds the taillights, etc. I also believe I confirmed that last night...
Went on a 10-minute trip last night. After a 1/4-mile my gauge cluster lights went out (I'm suspecting it's due to a lack of a cab -> frame ground). When I got to my buddy's house, 5 miles away, he said my taillights were out (I'm guessing due to a lack of a bed -> frame strap). Now it's got me wondering if the EVAP wasn't passing readiness tests because if that lack of ground... or due to not having one for the head -> firewall... or both.
So, I'm hoping to find some specific info on where the bed -> frame, block -> frame, and radiator support -> fender well grounds should go, as well as where I could add extra grounds to keep the gremlins away. I figure when I get these boxes checked I'll take pictures of all the locations for anyone else struggling with this (instead of reviving old, scattered discussions like I am [emoji6] )
Thanks for all the help so far.
Sent from my 2PS64 using Tapatalk
