lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I get a headache trying to read this thread... lay off the sugar man, lol
I've found that with filling the rear axle, sometimes it will start to run out but if you leave it sit a min it'll level itself off (gear oil is a bit thick) and you can finish filling. I usually try to put mine on a slight backward slope so that it's just a hair overfilled (which is how it comes from the factory).
If you have a limited slip rear axle, you should have friction modifier in with the gear oil, unless you used a good grade of synthetic (even then I might consider using it though).
Going to smaller tires will change your speedometer and odometer readings, thus you may percieve a difference, but it will be relatively minimal if you figure out the difference. If you're looking for great fuel economy, a truck just isn't it. I'd love to have something that got really great fuel economy, but since I do construction work and run my own business, it's just not practical for me to own a car, so I put big tires on my trucks and try not to cringe at the pump, lol.
