99 ranger 4x4 spindle broke
Dylan9302
2) 199
Hi guys I've been running around looking for this part.. For has one for 500 bucks.. I'm sure the part I broke is called a spindle but I could be wrong.. I broke the mount for the tie rod off it.. I know that only 98 - 2000 will work just for bolt in but what about Mazda? Will later years work? Because the only reason it wont work for a ranger is because the got rid of pulse hubs right? But did Mazda 4x4 switch?
Thanks dylan
You are talking about the steering knuckle.
Great.. Thanks, everyone calls it a spindle but about 15 scrappers dont have one. By if it's called a steering nubile that changes thinks.. I'll be looking tomoro again.
When I think spindle I think a 2wd truck that has the spindle as part of the steering knuckle (spindle is where the wheel bearings ride)
Yours being a 4x4 has a steering knuckle that the wheel bearing/hub assembly bolts to.
The older 4x4 trucks had a knuckle with removable spindle....
Ok thanks... Know I can Phone all the wreckers again.. Do you know which year Mazda work? Because I've heard the pvh right through to 2006?
I can't fully swear to it, but I'm pretty darn sure Mazda switched to the live-spindle setup at the same time the Rangers did, otherwise it seems I would've seen something about it by now.
98-2000...same as the ranger as they are the same truck.
Live close to NE Iowa, have a hole front laying in back of the garage from my sas
