99 4wd driveline vibration
N0lan
Olive hill, ky
Hey guys,
New to the forum, if I'm posting in the wrong place my apologies.
99 ranger 4wd 4.0L
I'm getting a strange driveline vibration that I can not narrow down. My girlfriend drove my truck last week, when she got home she said your truck is vibrating bad, unless you hit a bump or come to a complete stop and start again, then it goes away.
I took the truck for a 5 mile drive or so and nothing, everything seemed normal. Next day about 3 miles up the road I hit a small bump in the road and the vibration started. Vibrating the entire truck but seemed to be coming from the front end. I pull over and discovered the dust cap and passenger side auto locking hub was missing. That's how bad the vibration is, enough to vibrate off the dust cap and lock out. I came home jacked up the passenger side wheel, no play side to side or up and down.
My next thought was maybe since the lock out on one side was missing somehow the other side was engaged for some reason. Removed drivers side lock out, still same issue. On that test drive I noticed that if I put it into 4wd hi, the vibration would go away until I hit another bump. Then i would just flip it back to 2wd and back to 4wd and vibration gone once again.
This led me to believe it had to be the u-joint in the front shaft. I pulled the front shaft and noticed the u-joint moved freely with no binding on anything. So I proceeded to pull the shaft on the t-case side. Never seen a driveshaft quite like this one. Had to beat on it pretty hard to get it to come off and when it did the bearings fell out. On a side note, what type grease do I need to repack the front shaft with?
So with the front shaft removed, I went for a test drive, again 2 miles up the road and vibration is back, but prolly only half as bad as It was with front shaft in.
I have yet to pull the rear shaft but just by looking at the u-joints everything looks ok. No excessive play at rear yoke or on t-case side when u grab and shake the rear shaft.
With the front shaft still removed, it is still hard to pin point exactly where the vibration is coming from. Kind of just feels the like its everywhere. Obviously with the front shaft removed switching between 2 hi and 4 hi does nothing. I plan on pulling rear shaft tomorrow and replacing u.joints but was just curious if anyone else had experienced the same issue. I can drive a while and everything seem normal, then hit the slightest little bump in road and the vibration begins. Now without the front shaft in, the only way to get rid of it is come to a complete stop and start again and the vibration leaves until I hit another bump.
Sorry for such a long winded post. I'm hoping someone out there has experienced the same issue and can point me in the right direction.
I appreciate any and all help/advice.
I love my ranger, other than the crap mileage you get with the 4.0. It only had 43k on it when I bought it 5 years ago. After buying it I came to the conclusion that the previous owners didnt drive it much bc of the mileage.
